[GRASS-dev] Re: [GRASS GIS] #784: wx location wizard: fails to set
datum
trac at osgeo.org
Mon Oct 19 04:49:23 EDT 2009
#784: wx location wizard: fails to set datum
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-develbranch6
Resolution: fixed | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by hamish):
ok, thanks. Datum/ellips is back for NZMG/NZGD49.
I notice it does not let you pick datums S-42, SAD69, and Sasia, the Next
button stays greyed out. Presumably because they have upper case letters.
Also (for me at least) those 3 appear at the top of the list, not in
alphabetical order.
I also notice that +ellps= is leading to some other weirdness:
create a UTM projection with the sam69 datum (South American 1969)
PROJ_INFO ends up with:
ellps: australian
but no "datum:". and `g.region -p` comes up with:
datum: ** unknown (default: WGS84) **
(note the terms for both S.A. and Aust. are the same in the ellipse.table
file)
hmmmn, `proj -le` groups them:
aust_SA a=6378160.0 rf=298.25 Australian Natl & S. Amer.
1969
so names were expanded because GRASS knows more named datums/ellipsoids
than +proj terms do, but it is a lossy process in that the named
datum/ellipsoid is lost in favour of its constituent terms. And so GRASS
didn't see a datum line in the PROJ_INFO file and complained that one
wasn't set. (I guess the g.region logic could be improved too, but maybe
it has a point)
I am unsure of the implications for proj4 versions > 4.5.0 where datum
terms must now be defined on both sides of the reprojection (I assume
expanded version will be ok), and of the `g.region -p` "datum not defined,
assuming WGS84" effects when non-WGS84-like datum terms are present, even
if a name isn't.
If only for metadata purposes the non-matching datum and ellipsoid names
should be preserved if possible.
So now I'm wondering if we do have to fall back to writing the PROJ_INFO
file manually after all, instead of using `g.proj -c`. (AFAICS we have all
the info we need to do that by the time we get to the summary page)
At this point I'm starting to spin in circles due to ignorance so I'll
need to take a little time to study the python code to be able to provide
you with more useful feedback.
One last aesthetic request though, could the summary page break up the
Projection: $proj_name, $datum name
into two lines, with the datum (or ellipsoid) put on the second
Datum:
line? (change to Ellipsoid if datum was not given)
a semi-related (& perhaps dubious) enhancement to the PROJ_INFO construct
is to think about adding a new "epsg: " line to preserve that for export
meta-data and WMSs.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/784#comment:11>
