[GRASS-dev] Re: [GRASS-user] ImportError: No module named lib
Mon Oct 19 09:22:28 EDT 2009
[CC to grass-dev]
Rusiru Boteju wrote:
> i get this
> "ImportError: No module named lib"
> when i try to run the code in http://grass.osgeo.org/wiki/GRASS_and_Python#Python-SWIG_examples
> can any one help me :(
First, ensure that you don't have a file named grass.py in the current
directory (e.g. ensure that the swig/python directory isn't the
current directory).
Python always checks the current directory before $PYTHONPATH, so it
gets confused if the current directory contains a module with the same
name as a package.
I'm wondering whether grass.lib.grass (i.e. the bindings for libgis)
should be renamed (to e.g. gis, general, or core) to avoid confusion.
