[GRASS-dev] problem building grass trunk
Stefano Salvador stefano.salvador at gmail.com
Wed Oct 21 03:07:41 EDT 2009
> You can just compile it then run the not-installed executable directly.
This solution just works, I compiled everything with only an error in
r.in.wms but this is another problem.
Thanks,
Stefano
