[GRASS-dev] [GRASS GIS] #795: v.out.ogr and centroids in GRASS
	6.2.1 and PostGIS
    trac at osgeo.org
    Sat Oct 31 06:44:14 EDT 2009
#795: v.out.ogr and centroids in GRASS 6.2.1 and PostGIS
 Reporter:  hancar                                   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                                   |      Status:  new
 Priority:  normal                                   |   Milestone:
Component:  default                                  |     Version:  unspecified
 Keywords:  v.out.ogr centroid grass postgis gentoo  |    Platform:  Linux
      Cpu:  x86-32                                   |
 = v.out.ogr and centroids in GRASS 6.2.1 and PostGIS =
 As a gentoo user I used GRASS 6.2.1 and PostGIS 1.3.1
 The problem is, this command:
 v.out.ogr input=soils type=point,line,centroid dsn='PG:host=localhost
 dbname=spearpg user=postgres' olayer=soils format=PostgreSQL
 lco='OVERWRITE=YES'
 produces many of these print-outs:
 Command: INSERT INTO "soils" (wkb_geometry , "cat", "label") VALUES
 (GeomFromEWKT('SRID=2;LINESTRING (599923.53439599997364
 4925869.863033999688923)'::TEXT) , 11, 'CaE')
 ERROR 1: INSERT command for new feature failed.
 ERROR:  geometry requires more points
 whereas this:
  v.out.ogr input=soils type=point,line,boundary dsn='PG:host=localhost
 lco='OVERWRITE=YES'
 is OK.
 The problem appears when `type=cenroid` is among parameters. It produces
 the print-outs and centroids are missing in the output table.
Ticket URL: <http://trac.osgeo.org/grass/ticket/795>
