[GRASS-dev] Re: [GRASS GIS] #734: wxGui sqlbuilder: a few bugs
GRASS GIS trac at osgeo.org
Tue Sep 1 06:58:10 EDT 2009
  Reporter:  hamish  |       Owner:  martinl
      Type:  defect  |      Status:  assigned
  Priority:  major   |   Milestone:  6.4.0
 Component:  wxGUI   |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  sqlbuilder
  Platform:  Linux   |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:2 hamish]:
 >  - Columns and Values text boxes are now a bit too small,
 > only showing 1.5 column names + up/down slider. It would be
 > nice if it were big enough to at least show more of them.
 note that on an eeePC the default screen resolution is 1024x600,
 and the current window height for the SQL builder GUI (I get) is 525, so
 after you subtract 20px or so for the window manager taskbar(s) there
 isn't much room left for expansion. (The wx startup GUI is better than it
 used to be, but still the [enter grass] buttons are slightly crushed
 there)
 so it would be nice if gui widgets could be packed a little bit tighter
 and the starting window heights no taller than (say) 575px.
 (maybe smaller buttons for the = > < >= <=; move "Close dialog on apply"
 checkbox on to the same row as [Verify][Apply]; or rethink if full DB
 connection params are really needed at the top, or could swing down with a
 >,v or +,- expansion button?)
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/734#comment:3>
