[GRASS-dev] [GRASS GIS] #740: v.edit returns incorrect results on Windows
GRASS GIS trac at osgeo.org
Wed Sep 2 04:35:21 EDT 2009
 Reporter:  nuessli  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.4.0
Component:  Vector   |     Version:  unspecified
 Keywords:           |    Platform:  MSWindows XP
      Cpu:  x86-32   |
 How to produce the bug:
 -Import the data attached (v.in.ascii format=standard)
 -Ask for the IDs having cats=2 in layer 2 (v.edit layer=2 tool=select
 cats=2 type=centroid)
 =>Should return 3 ids but only 2 are returned...
 -Ask for the IDs having cat=3 in layer 1 (v.edit layer=1  tool=select
 cats=3 type=centroid)
 This has been tested on 3 different computers on Grass 6.3.0, Grass 6.4RC5
 and Grass 6.4svn(unknown revision). All give exactly the same wrong
 result.
 This happens only under Windows: Linux versions always return the correct
 result, namely 3 ids in the two cases.
Ticket URL: <http://trac.osgeo.org/grass/ticket/740>
