[GRASS-dev] Re: [GRASS GIS] #719: v.edit tool=break: breaking more then 6 coords and producing of an unexpected line
GRASS GIS trac at osgeo.org
Wed Sep 2 07:30:50 EDT 2009
unexpected line
  Reporter:  achim        |       Owner:  martinl
      Type:  defect       |      Status:  assigned
  Priority:  major        |   Milestone:  6.5.0
 Component:  Vector       |     Version:  svn-develbranch6
Resolution:               |    Keywords:  v.edit tool=break
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [ticket:719 achim]:
 > 1/2
 > using v.edit tool=break results for more than 6 coordinates in an error:
 "Attempt to delete dead feature".
 > after error message the topology of vector-file is destroyed:
 > WARNING: Size of 'coor' file differs from value saved in topology file
 > WARNING: Please rebuild topology for vector map
 > two equal coordinates result in an error, too
 > 2/2
 > breaking a line returns three(!) lines: the two desired and one straight
 connecting the breaking point and the end or start point of the input-line
 Can you attach testing data to the ticket (e.g. in GRASS ASCII format -
 v.out.ascii format=standard) and exact commands to reproduce buggy
 behaviour of v.edit? Thanks. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:3>
