[GRASS-dev] Re: [GRASS GIS] #377: gis.m/Map Display fails to handle vector layers with multiple databse layers
GRASS GIS trac at osgeo.org
Fri Sep 4 11:27:27 EDT 2009
layers
  Reporter:  ploewe  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Vector  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  gis.m database query
  Platform:  All     |         Cpu:  OSX/Intel
Comment (by neteler):
 Replying to [comment:2 cmbarton]:
 > The labeling is worse. I can get labels from layer 1 in the GUI, but
 from the command line to an xmon, I get...
 > The process has forked and you cannot use this CoreFoundation
 functionality safely. You MUST exec().
 > Break on
 __THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__()
 to debug.
 > ERROR eof from graphics driver.
 See
 http://lists.osgeo.org/pipermail/grass-user/2009-April/050038.html
 and
 http://developer.apple.com/mac/library/technotes/tn2005/tn2083.html#SECDAEMONVSFRAMEWORKS
Ticket URL: <http://trac.osgeo.org/grass/ticket/377#comment:4>
