[GRASS-dev] Heisenbug in v.out.ascii with column parameter: segfault
Soeren Gebbert soerengebbert at googlemail.com
Wed Sep 9 07:13:36 EDT 2009
Hmmm, the bad thing is that the segfault disappear when using valgrind.
The uninitialised value report must not point to the root of the segfault.
To enable detailed information, grass must be compiled with debug
information ... .
I don't know what to do.
Best regrads
Soeren
2009/9/9 Markus Neteler <neteler at osgeo.org>
> Here we are:
> GRASS 6.4.0svn (patUTM32):~ > valgrind --tool=memcheck v.out.ascii
> phd_area_main_cities column=name
> ==26104== Memcheck, a memory error detector.
> ==26104== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
> ==26104== Using LibVEX rev 1854, a library for dynamic binary translation.
> ==26104== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
> ==26104== Using valgrind-3.3.1, a dynamic binary instrumentation framework.
> ==26104== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
> ==26104== For more details, rerun with: -v
> ==26104==
> ==26104== Conditional jump or move depends on uninitialised value(s)
> ==26104==    at 0x4E4F408: db_enlarge_string (in
> /home/neteler/binaries/grass-6.4.0svn/lib/libgrass_dbmibase.6.4.0svn.so)
> ==26104==    by 0x4E4F50C: set_string (in
> ==26104==    by 0x4E4FD39: db_copy_value (in
> ==26104==    by 0x54DC58D: db_select_value (in
> /home/neteler/binaries/grass-6.4.0svn/lib/libgrass_dbmiclient.6.4.0svn.so)
> ==26104==    by 0x40210E: bin_to_asc (in
> /home/neteler/binaries/grass-6.4.0svn/bin/v.out.ascii)
> ==26104==    by 0x402A79: main (in
> ==26104==
> ==26104==    at 0x4E4F417: db_enlarge_string (in
> 664070.15136424|5103723.69345589|1|Trento
> 680631.89931785|5152080.37972013|2|Bolzano - Bozen
> 748566.88848245|5114436.80436153|3|Belluno
> 753217.48877466|5062320.47156408|4|Treviso
> 783478.0559796|5095956.26859946|5|Pordenone
> ==26104==
> ==26104== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 5 from 1)
> ==26104== malloc/free: in use at exit: 20,632 bytes in 186 blocks.
> ==26104== malloc/free: 495 allocs, 309 frees, 46,512 bytes allocated.
> ==26104== For counts of detected errors, rerun with: -v
> ==26104== searching for pointers to 186 not-freed blocks.
> ==26104== checked 779,376 bytes.
> ==26104==
> ==26104== LEAK SUMMARY:
> ==26104==    definitely lost: 13,863 bytes in 103 blocks.
> ==26104==      possibly lost: 0 bytes in 0 blocks.
> ==26104==    still reachable: 6,769 bytes in 83 blocks.
> ==26104==         suppressed: 0 bytes in 0 blocks.
> ==26104== Rerun with --leak-check=full to see details of leaked memory.
> Doesn't tell me too much... :( I guess an extra trick is needed to include
> DBMI checking.
> Markus
> On Wed, Sep 9, 2009 at 12:14 PM, Soeren
> Gebbert<soerengebbert at googlemail.com> wrote:
> > Hello,
> > try valgrind:
> > valgrind --tool=memcheck v.out.ascii phd_area_main_cities column=name
> > Sören
> >> Hi,
> >> I get a Heisenbug [1] when exporting points from v.out.ascii with
> >> attributes
> >> (Scientific Linux, 64bit):
> >> GRASS 6.4.0svn (patUTM32):~ > v.out.ascii phd_area_main_cities
> column=name
> >> Segmentation fault
> >> GRASS 6.4.0svn (patUTM32):~ > gdb v.out.ascii
> >> GNU gdb Red Hat Linux (6.5-37.el5_2.2rh)
> >> This GDB was configured as "x86_64-redhat-linux-gnu"...(no debugging
> >> symbols found)
> >> Using host libthread_db library "/lib64/libthread_db.so.1".
> >> (gdb) r phd_area_main_cities column=name
> >> Starting program:
> >> (no debugging symbols found)
> >> [Thread debugging using libthread_db enabled]
> >> [New Thread 47548720613104 (LWP 7517)]
> >> [Detaching after fork from child process 7520. (Try `set detach-on-fork
> >> off'.)]
> >> Program exited normally.
> column=name
> >> Segmentation fault
> >> Yes, I didn't compile with -g because it is my production machine but
> >> since it works in GDB...
> >> Any idea how to debug this problem?
> >> thanks
> >> Markus
> >> [1] http://en.wikipedia.org/wiki/Unusual_software_bug#Heisenbug
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090909/4623c60e/attachment.html
