[GRASS-dev] Re: [GRASS GIS] #746: v.out.ascii with column parameter: segfault
GRASS GIS trac at osgeo.org
Wed Sep 9 22:39:22 EDT 2009
  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  normal   |   Milestone:  6.4.0
 Component:  Vector   |     Version:  6.4.0 RCs
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-64
Comment (by glynn):
 Replying to [comment:1 hamish]:
 > it seems to die on this in db_select_value():
 if (count == 0)
     db_copy_value(val, value);
 > I'm guessing that *val has not been allocated any memory?
 Various dbString functions expect the target value to have been
 initialised, but "value" is uninitialised. It needs to be initialised
 with:
     dbValue value = {0};
 Alternatively, the string part alone can be initialised later with:
     db_init_string(&value.s);
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:4>
