[GRASS-dev] Re: [GRASS GIS] #755: trying to start in mapset you don't own gives wrong error msg
GRASS GIS trac at osgeo.org
Fri Sep 18 05:44:30 EDT 2009
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:  mapset access
  Platform:  Linux    |         Cpu:  x86-32
Old description:
> Hi,
> if I do "chmod 999.999 $LOCATION/user1" to make my user account not the
> owner of a mapset, and then start grass with the full path to the mapset
> I get this error:
> Cleaning up temporary files ...
> Starting GRASS ...
> $LOCATION/user1/.gislock: Permission denied
> ERROR: $GISBASE/etc/lock:
> hb is currently running GRASS in selected mapset (file
> $LOCATION/user1/.gislock found). Concurrent use not allowed.
> user1 is drwxr-xr-x, so the Permission denied comes from the fact that
> etc/lock can't write the .gislock file, not that my current user account
> already has a copy there. (I checked, the file doesn't exist)
> So that Permission denied needs to be better caught I guess.
> or improve  G!__mapset_permissions() or G!__mapset_permissions2() and
> it's a case of the error message being a bit too overenthusiastic?
> if I start GRASS with -tcltk the mapset is simply missing from the list
> (greyed out would be nicer if $MAPSET/WIND exists but we don't own it). I
> don't have wx on this machine to test the wxGUI startup, nor did I test
> changing mapsets with g.mapset. And no idea what happens if you force the
> mapset change with g.gisenv.
> Hamish
New description:
 owner of a mapset, and then start grass with the full path to the mapset I
 get this error:
 Starting GRASS ...
 hamish is currently running GRASS in selected mapset (file
 or improve  G!__mapset_permissions() or G!__mapset_permissions2() and it's
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/755#comment:1>
