[GRASS-dev] wxgui problem (grass -r 39224 linux x86_64 "sidux" )
Massimo Di Stefano massimodisasha at gmail.com
Sat Sep 19 16:32:40 EDT 2009
Hi
my swig version is :  1.3.39
Il giorno 19/set/09, alle ore 18:38, Martin Landa ha scritto:
> Hi,
> 2009/9/16 sasha <massimodisasha at gmail.com>:
>> def SetBackground(self, *args): return
>> _grass6_wxvdigit.PseudoDC_SetBackground(self, *args)
>> TypeError
>> in method 'PseudoDC_SetBackground', argument 2 of type
>> 'wxBrush const &'
> you are probably using different version of swig for building vector
> digitizer extension from the version which has been used for building
> wxPython library.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
