[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
Michael Barton Michael.Barton at asu.edu
Mon Sep 21 17:14:03 EDT 2009
Inside site_packages, the only think I've got is:
-a folder named wx-2.8-mac-unicode that has all the wxpython stuff in
it,
-a file called wxpython-2.8.10.1-py2.5.egg-info, and
-a file called wxversion.py
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262; fax: 480-965-7671
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Sep 21, 2009, at 2:00 PM, William Kyngesburye wrote:
> What about wxredirect.pth?
> On Sep 21, 2009, at 3:23 PM, Michael Barton wrote:
>> I've only got wxversion.py, no wx.pth
>> Michael
>> C. Michael Barton
>> USA
>>>>> Also, make sure there is only one wx path file in your site-
>>>>> packages,
>>>>> that points to your only installed wx.
>>>> How can I check this path?
>>> Look for a file along the lines of:
>>> 	.../python2.5/site-packages/wx.pth
>>> This will contain the (possibly relative) path of a directory to be
>>> added to the Python module path.
>>> E.g. I have:
>>> 	$ cat /usr/lib/python2.5/site-packages/wx.pth
>>> 	wx-2.8-gtk2-unicode
>>> This causes the directory
>>> 	/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode
>>> to be added to the module path, so "import wx" loads the file
>>> 	/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/__init__.py
>>> However: I'm not sure whether wx.pth is actually relevant if
>>> wxversion
>>> is used, as it modifies sys.path itself.
>>> Glynn Clements <glynn at gclements.plus.com>
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
