[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
Michael Barton Michael.Barton at asu.edu
Mon Sep 21 18:50:28 EDT 2009
OK. This proved to be the big clue.
Looking at my MacBook, I've got a python 2.5 distribution in /Library/
Frameworks/Python.frameworks.
It does not have a /Library/Python
My newer iMac is as you describe it with only /Library/Python/2.5/site-
packages. It does NOT have a /Library/Frameworks/Python.frameworks.
In spite of my attempts to get rid of it, it looks like I still have a
remnant MacPython distribution on my MacBook, although it is not in my
PythonPath. But it does have a wxPython in it.
I guess I need to copy /Library/Python from my iMac to my MacBook and
delete /Library/Frameworks/Python.frameworks from my MacBook. Correct?
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262; fax: 480-965-7671
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Sep 21, 2009, at 3:29 PM, William Kyngesburye wrote:
> I think we're converging on understanding what the other means ;)
> For that wxredirect.pth file, that should be in /Library/Python/2.5/
> site-packages.  No other wx files or folders whould be there, all as
> you say in /usr/local/lib/wxpython-unicode-[version].
> On Sep 21, 2009, at 5:10 PM, Michael Barton wrote:
>> I did not compile these. I've never compiled wxpython. These are
>> downloaded from the wxpython site as binaries and installed with
>> their packager.
>> They changed where the wxpython stuff is located several versions
>> back. It is now located in /usr/local/lib/wxpython[version number].
>> Inside of this is ../lib/Python2.5/site-packages/wx-2.8-mac-unicode/
>> wx and ../lib/Python2.5/site-packages/wx-2.8-mac-unicode/wxpython
>> Michael
>> C. Michael Barton
>> USA
>> On Sep 21, 2009, at 2:45 PM, William Kyngesburye wrote:
>>> that's strange - the installer should have put the whole wx package
>>> in /usr/local/lib/libwxpython-unicode-2.8.10.1, and only the
>>> wxredirect.pth in site-packages.
>>> Putting all the python parts in site-packages, and the wx libraries
>>> in /usr/local/lib, was the old way their installers worked.
>>> Are you sure this isn't the wxpython you compiled?
>>> try this, I'm curious (adjust the path if needed, I'm guessing):
>>> otool /Library/Python/2.5/wx-2.8-mac-unicode/wx/_core_.so
>>> There should be a path to libwx_macud-2.8.0.dylib in the output.
>>> On Sep 21, 2009, at 4:14 PM, Michael Barton wrote:
>>>> Inside site_packages, the only think I've got is:
>>>> -a folder named wx-2.8-mac-unicode that has all the wxpython stuff
>>>> in it,
>>>> -a file called wxpython-2.8.10.1-py2.5.egg-info, and
>>>> -a file called wxversion.py
>>>> Michael
>>>> C. Michael Barton
>>>> Change
>>>> USA
>>>> On Sep 21, 2009, at 2:00 PM, William Kyngesburye wrote:
>>>>> What about wxredirect.pth?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always
> now and always shall be, there is an eternity of time for the
> accomplishment of objects."
> - the wisdom of Tarzan
