[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
Michael Barton Michael.Barton at asu.edu
Mon Sep 21 19:10:09 EDT 2009
Somehow I was mistaken. My MacBook DOES have /Library/Python on it.
It does have wxredirect.pth which ONLY has a path to my current
wxpython 2.8.10.1.
/Library/Python/2.5/site-packages also has folders for numpy and
pyopenGL.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262; fax: 480-965-7671
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Sep 21, 2009, at 4:03 PM, William Kyngesburye wrote:
> All Macs should have a /Library/Python.  At least as far back as 10.4
> Tiger.  There are version sub-folders for each python installed in the
> system.  If it is missing completely on your MacBook, you may have
> accidentally deleted it.
> So, maybe you are building with the latest wxpython and the system
> Python, but then at runtime the python.org Python in /Library/
> Frameworks is run somehow with the other wxpython.  Or some such mixup
> somewhere.
> Copying /Library/Python from the iMac should be OK as long as they're
> both the same system, though you may want to reinstall python
> extensions like wxpython just to make sure they have all the support
> bits they need.
> On Sep 21, 2009, at 5:50 PM, Michael Barton wrote:
>> OK. This proved to be the big clue.
>> Looking at my MacBook, I've got a python 2.5 distribution in /
>> Library/Frameworks/Python.frameworks.
>> It does not have a /Library/Python
>> My newer iMac is as you describe it with only /Library/Python/2.5/
>> site-packages. It does NOT have a /Library/Frameworks/
>> Python.frameworks.
>> In spite of my attempts to get rid of it, it looks like I still have
>> a remnant MacPython distribution on my MacBook, although it is not
>> in my PythonPath. But it does have a wxPython in it.
>> I guess I need to copy /Library/Python from my iMac to my MacBook
>> and delete /Library/Frameworks/Python.frameworks from my MacBook.
>> Correct?
>> Michael
>> C. Michael Barton
>> USA
>> On Sep 21, 2009, at 3:29 PM, William Kyngesburye wrote:
>>> I think we're converging on understanding what the other means ;)
>>> For that wxredirect.pth file, that should be in /Library/Python/2.5/
>>> site-packages.  No other wx files or folders whould be there, all as
>>> you say in /usr/local/lib/wxpython-unicode-[version].
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
