[GRASS-dev] Re: [GRASS GIS] #590: wxGUI vector display forgets layer selection
GRASS GIS trac at osgeo.org
Tue Sep 22 03:00:46 EDT 2009
  Reporter:  mmetz        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  minor        |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by mmetz):
 Replying to [comment:1 cmbarton]:
 > When I open and then reopen the properties dialog for a vector the layer
 number does not change. Maybe I don't quite understand the issue here. I'm
 looking at this in the current (21 Sept 2009) version of devbr6 svn.
 Hmm, maybe this is a problem of my system? Using current versions of
 relbr6 and devbr6 (22 Sept 2009), the layer number still switches back to
 1 after a split second if I selected layer 3 or 5 previously. The display
 however still shows the correct selection for the previously selected
 layer, that only changes after I manually change the layer number.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/590#comment:2>
