[GRASS-dev] Re: [GRASS GIS] #590: wxGUI vector display forgets layer selection
Markus Metz markus.metz.giswork at googlemail.com
Tue Sep 22 12:02:17 EDT 2009
Michael Barton wrote:
> Martin,
> Can you send me the multi-layer vector file that gives you trouble?
> I'll test it specifically.
Taken from ticket 577:
https://trac.osgeo.org/grass/attachment/ticket/577/test_5.gpx?format=raw
After import with v.in.ogr, the vector has no features in layer 1, 1
line in layer 3 and 4 points in layer 5.
Thanks,
Markus M
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
>> Reporter: mmetz | Owner: grass-dev at lists.osgeo.org
>> Type: defect | Status: new
>> Priority: minor | Milestone: 7.0.0
>> Component: wxGUI | Version: svn-develbranch6
>> Resolution: | Keywords:
>> Platform: Unspecified | Cpu: Unspecified
>> Comment (by mmetz):
>> Replying to [comment:1 cmbarton]:
>>> When I open and then reopen the properties dialog for a vector the
>>> layer
>> number does not change. Maybe I don't quite understand the issue
>> here. I'm
>> looking at this in the current (21 Sept 2009) version of devbr6 svn.
>> Hmm, maybe this is a problem of my system? Using current versions of
>> relbr6 and devbr6 (22 Sept 2009), the layer number still switches
>> back to
>> 1 after a split second
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
