[GRASS-dev] Re: [GRASS GIS] #757: WinGRASS: GUI window from cmd line
GRASS GIS trac at osgeo.org
Tue Sep 22 15:44:37 EDT 2009
  Reporter:  silviap       |       Owner:  grass-dev at lists.osgeo.org
      Type:  task          |      Status:  new
  Priority:  trivial       |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by cnielsen):
 A bit of misunderstanding here. GRASS is starting fine, but once open the
 dialogs of individual modules aren't opening when they are typed into the
 shell. Instead if you type {{{ r.walk }}} or whatever, the module's ascii
 help text is output to the shell (as required arguments are missing, ie.
 output) instead of opening a dialog window where the arguments may be
 entered.
 -Colin
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:7>
