[GRASS-dev] Re: [GRASS GIS] #618: rfe: r.md5sum or equivalent
GRASS GIS trac at osgeo.org
Thu Sep 24 01:47:53 EDT 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:               |    Keywords:  testsuite, r.univar, md5sum
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 - for this task we care about data not how it is stored, so probably after
 endian translation
  - not sure if the differences in how FPs are stored makes this an
 impossiblity. (false negatives)
  - probably for this task we care about entire map not subregion(?) so not
 clipped to current region. or maybe you want to check that a subregion is
 the same (eg r.patch result..)
 H
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:4>
