[GRASS-dev] 3D Vector to Voxel
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Tue Sep 29 10:05:07 EDT 2009
That looks really useful. There is probably a myriad of other
classes in VTK that could be used by GRASS modules, too.
I guess the best way would be to write some add-on
modules that depend on VTK and the GRASS bridge and
expose some VTK classes to the GRASS CLI.
However, then I would have to learn C++ ;)
How about the OpenGL coordinate precision problem?
Beń
----- Original Message -----
From: "Soeren Gebbert" <soerengebbert at googlemail.com>
To: "Benjamin Ducke" <benjamin.ducke at oxfordarch.co.uk>
Cc: "GRASS developers list" <grass-dev at lists.osgeo.org>
Sent: Tuesday, September 29, 2009 2:49:53 PM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
Subject: Re: [GRASS-dev] 3D Vector to Voxel
Hello Ben,
2009/9/21 Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
> Hi all,
> I just saw a little GPL'd sofwtare that may provide a base for
> a v.to.r3 module that could actually cast arbitrary vector geometries
> to a voxel grid:
Have a look at the vtkVoxelModeller class :
http://www.vtk.org/doc/release/5.4/html/a01861.html
or the vtkImplicitModeller class:
http://www.vtk.org/doc/release/5.4/html/a00859.html
Booth classes convert arbitrary datasets to a voxel representations.
I have just committed a grass vector topology reader to the vtkGRASSBridge
repository.
Maybe you can now create voxel representations of 3d grass vector
data, using GRAS, VTK and vtkGRASSBridge?
Best regards
Soeren
> http://www.cs.princeton.edu/~min/binvox/
> maybe someone would like to look at possibilities for integrating
> this into GRASS?
> Best,
> Ben
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
