[GRASS-dev] Re: i.rgb.his/i.his.rgb and 16bit images
Hamish hamish_b at yahoo.com
Wed Sep 30 12:37:09 EDT 2009
Hamish wrote:
> where is rgb2his.c, I don't see it in grass 6.5
> if that is a C module, ideally the 256 should be made a
> module option which defaults to 256.
[... time passes ... I found it ...]
> see attached patch x6.5,
H
