[GRASS-dev] Add operations/functions when closing
Franz Schiller franzschiller1975 at gmail.com
Mon Apr 5 13:07:16 EDT 2010
Ok Thanks Glynn.. I suppose that ending/closing code is from "trap 2 3 15
"aproximately at line 996. Right? SO at that point I can still use grass
scripts and commands? (e.g. r.in.gdal or export rotines)?
Thank you
Franz
On Sat, Apr 3, 2010 at 12:09 AM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Franz Schiller wrote:
> > I would like to know If I can add operations/functions to the closing
> > function of GRASS (e.g. delete temporary files or resetting files)
> > If it0s possible, how can I do that? Or where shall I add code/functions?
> $GISBASE/etc/Init.sh.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100405/7d916576/attachment.html
