[GRASS-dev] Unable to find grass7 start script after svn update/recompile
Soeren Gebbert soerengebbert at googlemail.com
Tue Apr 6 08:45:47 EDT 2010
Hello Martin,
2010/4/6 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2010/4/6 Soeren Gebbert <soerengebbert at googlemail.com>:
>> i have a problem starting grass7 from the "dist" directory.
>> I recently  made an svn update and recompiled grass7 from scratch.
>> Now the grass7 start script is missing in the "dist" directory.
> you can find start script in "bin" directory (`grass70`).
Unfortunately not:
grass_trunk> find dist.i686-pc-linux-gnu/ -name \*grass70\*
grass_trunk>
It looks to me that the start script is not generated in the dist directory.
Soeren
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
