[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass release
GRASS GIS trac at osgeo.org
Thu Apr 8 05:04:35 EDT 2010
  Reporter:  cnielsen      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Tcl           |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass,v.digit
  Platform:  MSWindows XP  |         Cpu:  x86-64
Comment (by marisn):
 Ah. Sorry - slipped under my radar. I clearly see error message, still
 resulting vector seems to be fine, as displaying, query, v.info and
 v.report are running fine without errors.
 Here's output when creating new map "bar" with single point without
 attribute information:
 D2/3: Variable = 0040E0C0
 D1/3: Vect_get_thresh(): thresh = 0.000000
 D2/3: topo body offset 142
 D1/3: Vector format: 0 (native)
 D1/3: Vect_set_thresh(): thresh = 0.000000
 D1/3: Vect__read_head(): vector = bar at user1
 D1/3: Level request = 0
 D1/3: Vect_open_topo(): name = bar mapset= user1
 D1/3: get coor info: C:\Users\Maris\Documents\GIS
 DataBase/spearfish60/user1/vector/bar/coor
 D1/3: Info->size = 14, Info->mtime = 1270717167
 D2/3: Topo header: file version 5.0 , supported from GRASS version 5.0
 D2/3:   byte order 0
 D2/3:   header size 142
 D2/3:   with_z 0
 D2/3:   coor size 14
 D1/3: Topo head: coor size = 14, coor mtime = 1270717167
 D1/3: dig_load_plus()
 D3/3: dig_init_plus()
 D1/3: dig_spidx_init()
 D3/3: dig_cidx_init()
 D2/3:   byte order 0
 D2/3:   with_z 0
 D2/3:   coor size 14
 D3/3: dig_alloc_isle():
 D2/3: Vect_cidx_open(): name = bar mapset= user1
 D3/3: dig_read_cidx()
 D3/3: Cidx header: file version 5.0 , supported from GRASS version 5.0
 D2/3: Vect_cidx_save()
 D2/3: Open cidx: C:\Users\Maris\Documents\GIS
 DataBase/spearfish60/user1/vector/bar/cidx
 D3/3: dig_write_cidx_head()
 D3/3: cidx body offset 13
 D1/3: close history file
 D1/3: V1_close_nat(): name = bar mapset= user1
 D2/3: ftell = 14
 D1/3: dig__write_head()
 D1/3: write coor size (14) to head
 D2/3: coor body offset 14
 D1/3: Vect_write_dblinks(): map = bar, mapset = user1
 D1/3: dbln file: C:\Users\Maris\Documents\GIS
 DataBase/spearfish60/user1/vector/bar/dbln
 D1/3: Dblinks written
 D1/3: Vect_open_old(): name = bar mapset= user1 update = 1
 D1/3: open format file: 'user1/vector/bar/frmt'
 D1/3: write coor size (0) to head
 D3/3: Vect_build(): build = 4
 Building topology for vector map <bar>...
 D2/3: dig_cidx_free()
 D3/3: Vect_build_nat() build = 4
 D1/3: Vect_Rewind(): name = bar
 Registering primitives...
 D3/3: Vect_read_next_line()
 D3/3: V1_read_next_line_nat()
 D3/3: Vect__Read_line_nat: offset = 14
 0 primitives registered
 0 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Attaching islands...
 Attaching centroids...
 D2/3: dig_cidx_sort()
 Number of nodes: 0
 Number of primitives: 0
 Number of points: 0
 Number of lines: 0
 Number of boundaries: 0
 Number of centroids: 0
 Number of areas: 0
 Number of isles: 0
 D1/3: Vect_close(): name = bar, mapset = user1, format = 0, level = 2
 D2/3: ftell = 14
 D1/3: Vect_save_topo()
 D1/3: Open topo: C:\Users\Maris\Documents\GIS
 DataBase/spearfish60/user1/vector/bar/topo
 D2/3: G__read_Cell_head
 D2/3: G__read_Cell_head_array
 D3/3: region item: proj:       1
 D3/3: region item: zone:       13
 D3/3: region item: north:      4928010
 D3/3: region item: south:      4913700
 D3/3: region item: east:       609000
 D3/3: region item: west:       589980
 D3/3: region item: cols:       634
 D3/3: region item: rows:       477
 D3/3: region item: e-w resol:  30
 D3/3: region item: n-s resol:  30
 D3/3: region item: top:        1
 D3/3: region item: bottom:     0
 D3/3: region item: cols3:      634
 D3/3: region item: rows3:      477
 D3/3: region item: depths:     1
 D3/3: region item: e-w resol3: 30
 D3/3: region item: n-s resol3: 30
 D3/3: region item: t-b resol:  1
 D1/3: Region: N = 4928010.000000 S = 4913700.000000 E = 609000.000000 W =
 589980.000000
 Jauna tukða karte ir izveidota.
 D2/3: Vect_open_new(): name = bar
 D1/3: V1_open_new_nat(): name = bar
 D3/3:   byte order 0
 D3/3:   header size 9
 D1/3: V1_open_old_nat(): name = bar mapset = user1
 D2/3: Coor header: file version 5.1 , supported from GRASS version 5.1
 D2/3:   byte order 0
 D2/3:   with_z 0
 D2/3:   coor size 14
 D1/3: coor size in head = 14, real coor file size= 14
 D1/3: Vect_open_old(): vector opened on level 2
 D1/3: Vect_read_dblinks(): map = bar, mapset = user1
 D3/3: Searching for FID column in OGR DB
 D1/3: Dblinks read
 D3/3: Vect_build_sidx_from_topo()
 D3/3: Spatial index was built
 D3/3: Vect_hist_command()
 D3/3: G_recreate_command()
 D1/3: Map opened
 D2/3: cat_init()
 D2/3: symb_line_init()
 D2/3: symb_node_init()
 D3/3: Starting Tk_Main.
 D3/3: v.digit Tcl_AppInit (...)
 D3/3: Starting toolbox.tcl
 D3/3: c_tool_centre()
 D2/3: var_init
 D2/3: cat_max_get() field = 1
 D2/3: display_bg()
 D2/3: display_map()
 D2/3: set color to symb 2: 255 255 0
 D2/3: set color to symb 13: 0 153 0
 D2/3: set color to symb 12: 255 0 0
 D2/3: get_symb_code(): name = background
 D2/3: -> code = 1
 D2/3: i_set_color(): background : 255 255 255
 D2/3:  -> color = #ffffff
 D2/3: i_set_on(): background : 1
 D2/3: get_symb_code(): name = highlight
 D2/3: -> code = 2
 D2/3: i_set_color(): highlight : 255 255 0
 D2/3:  -> color = #ffff00
 D2/3: i_set_on(): highlight : 1
 D2/3: get_symb_code(): name = point
 D2/3: -> code = 3
 D2/3: i_set_color(): point : 0 0 0
 D2/3:  -> color = #000000
 D2/3: i_set_on(): point : 1
 D2/3: get_symb_code(): name = line
 D2/3: -> code = 4
 D2/3: i_set_color(): line : 0 0 0
 D2/3: i_set_on(): line : 1
 D2/3: get_symb_code(): name = boundary_0
 D2/3: -> code = 5
 D2/3: i_set_color(): boundary_0 : 153 153 153
 D2/3:  -> color = #999999
 D2/3: i_set_on(): boundary_0 : 1
 D2/3: get_symb_code(): name = boundary_1
 D2/3: -> code = 6
 D2/3: i_set_color(): boundary_1 : 255 125 0
 D2/3:  -> color = #ff7d00
 D2/3: i_set_on(): boundary_1 : 1
 D2/3: get_symb_code(): name = boundary_2
 D2/3: -> code = 7
 D2/3: i_set_color(): boundary_2 : 0 255 0
 D2/3:  -> color = #00ff00
 D2/3: i_set_on(): boundary_2 : 1
 D2/3: get_symb_code(): name = centroid_in
 D2/3: -> code = 8
 D2/3: i_set_color(): centroid_in : 0 0 153
 D2/3:  -> color = #000099
 D2/3: i_set_on(): centroid_in : 1
 D2/3: get_symb_code(): name = centroid_out
 D2/3: -> code = 9
 D2/3: i_set_color(): centroid_out : 153 153 0
 D2/3:  -> color = #999900
 D2/3: i_set_on(): centroid_out : 1
 D2/3: get_symb_code(): name = centroid_dupl
 D2/3: -> code = 10
 D2/3: i_set_color(): centroid_dupl : 255 0 255
 D2/3:  -> color = #ff00ff
 D2/3: i_set_on(): centroid_dupl : 1
 D2/3: get_symb_code(): name = node_1
 D2/3: -> code = 12
 D2/3: i_set_color(): node_1 : 255 0 0
 D2/3:  -> color = #ff0000
 D2/3: i_set_on(): node_1 : 1
 D2/3: get_symb_code(): name = node_2
 D2/3: -> code = 13
 D2/3: i_set_color(): node_2 : 0 153 0
 D2/3: Cat modes: $GWidget(cat_mode) configure -values [list "No category"
 "Manual entry" "Next not used"]
 D2/3:  -> color = #009900
 D2/3: i_set_on(): node_2 : 1
 D3/3: c_update_tool()
 D3/3: c_next_tool()
 D2/3:   Tool_next = 2
 D2/3: new_line(): type = 1
 D2/3: Cat mode: $GWidget(cat_mode) setvalue @2
 D3/3: new_line(): End
 D3/3: button = 1 x = 216 = 596366.280992 y = 184 = 4922569.834711
 D2/3: snap(): x = 596366.280992, y = 4922569.834711
 D3/3: Vect_find_node() for 596366.280992 4922569.834711 0.000000 maxdist =
 295.661157
 D3/3: Vect_select_nodes_by_box()
 D3/3: Box(N,S,E,W,T,B): 4.922865e+006, 4.922274e+006, 5.966619e+005,
 5.960706e+005, 1.#INF00e+000, -1.#INF00e+000
 D3/3: dig_select_nodes()
 D3/3:   0 nodes selected
 D3/3:  0 nodes in box
 D2/3: node = 0 x = 596366.280992, y = 4922569.834711
 D2/3: write field = 1 cat = 1
 D2/3: cat_max_set() field = 1 cat = 1
 D3/3: Vect_write_line(): name = bar, format = 0, level = 2
 D3/3: V2_write_line_nat()
 D3/3: Register node: type = 1,  596366.280992,4922569.834711
 D3/3: dig_find_node()
 D3/3: node = 0
 D3/3: dig_add_node(): n_nodes = 0, alloc_nodes = 0
 D3/3: dig_spidx_add_node(): node = 1, x,y,z = 596366.280992,
 4922569.834711, 0.000000
 D3/3: new node = 1, n_nodes = 1, alloc_nodes = 1000
 D3/3: Add new node: 1
 D3/3: dig_node_add_line(): node = 1 line = 1
 D3/3: dig_node_alloc_line(): add = 1
 D3/3:     angle = -9.000000
 D3/3: dig_node_add_line(): line 1 added position 0 n_lines: 1 angle
 -9.000000
 D3/3: dig_node_add_updated(): node = 1
 D3/3: dig_spidx_add_line(): line = 1
 D3/3: dig_line_add_updated(): line = 1
 D3/3:   line added to topo with id = 1
 D3/3: dig_cidx_add_cat_sorted(): field = 1 cat = 1 line = 1 type = 1
 D3/3: Added new category to index
 D3/3: updated lines : 1 , updated nodes : 1
 D2/3: Updated line: 1
 D2/3: Updated node: 1
 D2/3: set color to symb 1: 255 255 255
 D2/3: display_node(): node = 1 color = 1
 D2/3: display_icon()
 D2/3: symb_updated_lines_set_from_map();
 D2/3: line_symb_refresh()
 D2/3: line_symb_from_map(): line = 1
 D3/3: Vect_read_line()
 D3/3: V2_read_line_nat(): line = 1
 D3/3:     type = 1, do_cats = 1 dead = 0
 D3/3:     n_cats = 1
 D3/3:     n_points = 1
 D3/3:     off = 43
 D2/3: node_update();
 D2/3: node = 1 nl = 1
 D2/3: i = 0 line = 1
 D3/3:     n_cats = 1
 D3/3:     n_points = 1
 D3/3:     off = 43
 D2/3: node = 1 nlines = 0
 D2/3: display_line(): line = 1 color = 0
 D3/3:     n_cats = 1
 D3/3:     n_points = 1
 D3/3:     off = 43
 D2/3: set color to symb 3: 0 0 0
 D3/3: button = 3 x = 216 = 596366.280992 y = 184 = 4922569.834711
 D3/3: c_next_tool()
 D2/3:   Tool_next = 1
 D2/3: Quit
 D1/3: end()
 D3/3: Vect_build(): build = 0
 D3/3: Vect_build_nat() build = 0
 D2/3: dig_free_plus_areas()
 D2/3: dig_free_plus_isles()
 D2/3: dig_free_plus_nodes()
 D2/3: dig_free_plus_lines()
 D3/3:     n_cats = 1
 D3/3:     n_points = 1
 D3/3:     off = 43
 D3/3: Register line: offset = 14
 D3/3: node = 0
 -9.000000
 D3/3: dig_cidx_add_cat(): field = 1 cat = 1 line = 1 type = 1
 D3/3: Vect__Read_line_nat: offset = 43
 1 primitives registered
 1 vertices registered
 Building areas...
 0 areas built
 0 isles built
 Number of nodes: 1
 Number of primitives: 1
 Number of points: 1
 Number of lines: 0
 Number of areas: 0
 Number of isles: 0
 D2/3: ftell = 43
 D1/3: Info->size = 43, Info->mtime = 1270717167
 D3/3: dig_Wr_P_node()
 D3/3: cidx 0 head offset: 13
 D3/3: cidx 0 offset: 0
 D3/3: cidx body offset 41
 D1/3: write coor size (43) to head
 Region restored to original extent.
 D3/3: c_next_tool()
 D2/3:   Tool_next = 1
 D2/3: Quit
 D1/3: end()
 Building topology for vector map <(null)>...
 Unable to read vector map
 D1/3: Vect_close(): name = (null), mapset = (null), format = 0, level = 1
 D3/3: cidx 0 offset: 41
 D2/3: ftell = 43
Ticket URL: <https://trac.osgeo.org/grass/ticket/843#comment:31>
