[GRASS-dev] WinGrass7-installer + "GRASS 7.0.SVN with MSYS"-desktop-shortcut
Helmut Kudrnovsky hellik at web.de
Fri Apr 9 15:18:02 EDT 2010
hi,
with the last modifications of the WinGrass7 and WinGrass7-installer, Grass7 is started by the grass70.py script.
if you start with the "GRASS-70-SVN"-desktop-shortcut, you get WinGrass7 starting AND in the background a full functional windows-console.
in this windows-console you can start - if you want within a Grass7-session - python or a shell (in this shell you have access to sed, awk, ...) and can use also all windows-commandline-tools.
the "GRASS 7.0.SVN with MSYS"-desktop-shortcut is broken at the moment.
so I would opt for deleting the "GRASS 7.0.SVN with MSYS"-desktop-shortcut, because a full functional commandline is available (see above).
and the docs should be adapted for this.
any opinion?
best regards
Helmut
___________________________________________________________
NEU: WEB.DE DSL für 19,99 EUR/mtl. und ohne Mindest-Laufzeit!
http://produkte.web.de/go/02/
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100409/6f798e63/smime.bin
