[GRASS-dev] r.buffer python script breaks from within r.fillnulls
Yann Chemin yann.chemin at gmail.com
Mon Apr 12 00:47:35 EDT 2010
Hello list,
Could anybody help?
...using r.fillnulls on today's svn:
(Mon Apr 12 14:38:51 2010)
r.fillnulls --overwrite input=las_clean at PERMANENT output=las_spline
tension=40.0 smooth=0.1
Locating and isolating NULL areas...
  File "/usr/local/grass-7.0.svn/scripts/r.buffer", line
144, in <module>
    main()
105, in main
    if kv['+proj'] == 'longlat':
KeyError: '+proj'
Raster map <r.buffer.tmp.29582.src> not found
<r.buffer.tmp.29582.src> nothing removed
Raster map <r.buffer.tmp.29582.dist> not found
<r.buffer.tmp.29582.dist> nothing removed
ERROR: abandoned. Removing temporary map, restoring user mask if needed:
Removing raster <r_fillnulls_29574>
Removing raster <r_fillnulls_29574.buf>
Raster map <r_fillnulls_29574.buf> not found
<r_fillnulls_29574.buf> nothing removed
Removing raster <r_fillnulls_29574_filled>
Raster map <r_fillnulls_29574_filled> not found
<r_fillnulls_29574_filled> nothing removed
Error in atexit._run_exitfuncs:
  File "/usr/lib/python2.5/atexit.py", line 24, in
_run_exitfuncs
    func(*targs, **kargs)
  File "/usr/local/grass-7.0.svn/scripts/r.fillnulls", line
68, in cleanup
    grass.run_command('g.remove', flags = 'f', vect =
vecttmp)
NameError: global name 'vecttmp' is not defined
Error in sys.exitfunc:
_run_exitfuncs
68, in cleanup
vecttmp)
(Mon Apr 12 14:38:52 2010) Command finished (0 sec)
Yann Chemin
Senior Spatial Hydrologist
www.csu.edu.au/research/icwater
M +61-4-3740 7019
