[GRASS-dev] Re: New DWG import module
Rodrigo Rodrigues da Silva pitanga at members.fsf.org
Mon Apr 12 18:04:32 EDT 2010
On 13-03-2010 13:44, Markus Neteler wrote:
> On Thu, Dec 24, 2009 at 10:16 PM, Rodrigo Rodrigues da Silva
> <pitanga at members.fsf.org>  wrote:
>> There are some preliminary results on the module I've been writing. It
>> is a DWG file (http://www.naval.com/drawings/dwg/PRA430d.dwg - there's
>> a PDF too) that we've been using with testSVG, rendered with GRASS's
>> nviz module.
> (somewhat late answer)
> Congratulations to your first results!
Sorry I haven't seen your reply before. I have left work on that module
behind for a while due to LibreDWG issues. Now the issues seem to be
addressed and I plan to get back to work on the module by next week. I
was wondering if I could get access to the Addons SVN, and if someone
would be wanting to mentor me on that (I've read RFC2). I can publish a
tarball before that for evaluation, but I'd like to make it available to
the community anyway.
>> I think that it looks a bit aliased, maybe because GRASS
>> is tuned for larger orders of magnitude (kilometers) by default, and
>> not circuit boards (centimeters) -- I'm just wondering, I'm not a
>> GRASS user nor a SIG specialist. I need to test it with a proper DWG
>> file or change some configurations.
> No, GRASS can work with any unit, also nanometers if you want.
> The problem must be elsewhere.
> For inspection, you can use v.out.ascii to see the vectors in ASCII.
I'll check it out, thanks.
>> I'll submit it as soon as I get the INSERTs and BLOCKs working.
>> Rodrigo.
> Markus
GNU LibreDWG maintainer
FSF Associate Member #7788
PoliGNU - Grupo de Estudos de Software Livre da Poli/USP
