[GRASS-dev] GNU scientific library in GRASS
Soeren Gebbert soerengebbert at googlemail.com
Tue Apr 13 08:12:58 EDT 2010
Hello,
2010/4/13 Jarosław Jasiewicz <jarekj at amu.edu.pl>:
> Hi All!
> What about using GNU scientific library  (gsl) in GRASS module?
> Will it create additional dependencies?
Yes.
> What about compiling on windows?
> Any other contraindications??
> In general what I want to use I cannot find in gmath library.
What kind of algorithms are missing in gmath library?
GRASS7 already includes a numerical library called ccmath. Have a look
in the gmath-ccmath wrapper in lib/gmath.
Currently only a few algorithms from ccmath are used: eigenvalue
computation, LU decomposition and SVD solver. Have a look at the
ccmath library (http://freshmeat.net/projects/ccmath/). Maybe the
algorithms you are searching for is present there? If this is the case
we can add it to grass7.
Sören
> thanks for any answer
> J.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
