[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter information in command line help
GRASS GIS trac at osgeo.org
Tue Apr 13 11:25:45 EDT 2010
  Reporter:  huhabla      |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  7.0.0
 Component:  libgis       |     Version:  svn-trunk
Resolution:               |    Keywords:  parser, help
  Platform:  All          |         Cpu:  All
Comment (by martinl):
 Replying to [comment:9 glynn]:
 > Replying to [comment:7 martinl]:
 > > Probably we should think about the optimalization of the attributes in
 struct Option
 > Yes please.
 > I've been suggesting that the "type system" should be re-worked since
 roughly forever. I would have hoped that the wxGUI development would
 produce some feedback, but so far that hasn't happened.
 Can you elaborate a bit on your suggestion? From wxGUI POV it's required
 to have info about
 multiple               widget properties
 description and label  widget label + tooltip
 guidependency          to updated related widgets (e.g. database -> table
 -> column)
 age                    widget properties (e.g. show only maps from current
 maps for 'new')
 required               options for 'required tab'
 value                  widget value
 guisection             tabs
 prompt                 for widget type (gselect.*)
 type                   input validation
 see also #278
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:10>
