[GRASS-dev] launch i.class from Wxpython in GRASS6.4- question updated
António Rocha antonio.rocha at deimos.com.pt
Thu Apr 15 08:34:59 EDT 2010
YOu are absolutely right. I meant when I insert i.class in GRASS GIS
layer manager Command line it opens a Menu but nothing happens.  DOes
the same thing happens in 6.5 or GRASS7?
By the way, I tried to use i.class and I got a output signature file a
bit of incomplete:
#A
2565
#A
2565
#C
3500
#C
7351
#F
5381
What might be happening?
Thank you Martin
Martin Landa wrote:
> Hi,
> 2010/4/15 António Rocha <antonio.rocha at deimos.com.pt>:
>> I tried to run i.class in GRASS6.4 for UBUNTU, from Wxpython menu and it
>> doesn't launch anything. If I recall a some past emails, I have to use d.mon
> using fresh GRASS 6.4 from SVN, i.class starts from the menu without
> problem. Are you using RCs?
> Martin
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5030 (20100415) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
