[GRASS-dev] 6.4.0 blocker bugs
Markus Neteler neteler at osgeo.org
Sun Apr 18 04:44:52 EDT 2010
On Sat, Apr 10, 2010 at 1:31 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2010/4/10 Glynn Clements <glynn at gclements.plus.com>:
>> 6.4.0 should be sync'd to 6.5. Maybe 6.5 should be sync'd to 7.0
>> first, with one exception: the 7.0 version of grass.script.mapcalc()
> 6.5 sync'ed with 7.0 in r41773, after some testing can be backported to 6.4.
I have tried to generate a new vector map with the new digitizer, but it fails:
Unable to initialize display driver of vector digitizer. See 'Command
output' for details.
Reason: <unprintable DigitError object>
  File "/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/toolbars.py",
line 1123, in StartEditing
    message=_("Unable to initialize display driver of vector "
DigitError: <unprintable DigitError object>
wxNVIZ starts correectly in 6.5.
Attached the derived 6.4 backport from r41773 with a full sync of
core.py (not sure
if that's right). Testing that, also a (different) Python problem when
generating
a new vector map in the digitizer:
Details: 'NoneType' object has no attribute 'OpenMap' ()
Also wxNVIZ does not start here, so the attached backport isn't ok yet.
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100418/3680bfbd/lib_python_g64.obj
