[GRASS-dev] error in datacatalog
Mohammed Rashad rashadkm at gmail.com
Tue Apr 20 14:42:46 EDT 2010
a map is displayed on application directory map.png !!! when i switch
between displays the map.png changes
but no map is displayed on mapwindow. strange!!
On Tue, Apr 20, 2010 at 10:58 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Apr 20, 2010 at 3:45 PM, Mohammed Rashad <rashadkm at gmail.com>
> wrote:
> > I am developing an addon for grass gis. it can view,copy,rename,delete
> maps
> > in different location and mapset.
> Sounds great! The only limitation for cross-location copying/moving of
> maps is that the projection just be the same.
> > It can now display maps in same location and different mapsets. but when
> i
> > change location an error is occured using spearfish data
> > ERROR: Raster map <streams at PERMANENT> not found
> http://trac.osgeo.org/grass/browser/grass-addons/gui/wxpython/data_catalog
> I am afraid that only debugging statements will tell you where the
> path info gets lost.
> Similar for the slow display problem which you reported.
> Markus
Regards,
Mohammed Rashad K.M
http://keralainfo.web4all.in/
+919496620801
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100421/8ad6006f/attachment.html
