[GRASS-dev] New version of the r.landscape.evol.py Landscape Evolution module uploaded to the GRASS Addons repository.
Isaac Ullah isaac.ullah at asu.edu
Thu Apr 29 18:14:28 EDT 2010
I have built this functionality into the code, so r.watershed MFD
functionality will be used if available, regardless of which GRASS version.
However, our wired ethernet is out, so I cannot commit is to SVN until they
fix that (the computer I keep the versions on does not have a wifi card). I
will commit these changes to SVN as soon as the internet is restored to us!
Cheers,
Isaac
On Thu, Apr 29, 2010 at 10:15 AM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
> We should be able to implement the Python version of this code idea fairly
> easily. It looks like it might be the better method from a programming point
> of view, as it tests for the presence of the actual flag, rather than for a
> version number which will infer usage of the flag, and which could change
> depending upon the development branch and backporting decisions.
> On Wed, Apr 28, 2010 at 10:58 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>> On Apr 28, 2010, at 10:31 PM, Hamish wrote:
>> > oh by the way, my current favourite shell script way of testing if a
>> flag
>> > exists (yet) in a module is not to test the version/revision, but to do
>> a
>> > more direct query:
>> >  r.watershed --interface-description | grep -c '<flag name="f">'
>> > which should return 0 or 1.
>> > Hamish
>> This won't work on Windows, however, except under msys.
>> Michael
> Isaac I Ullah, M.A.
> Archaeology PhD Candidate,
> ASU School of Evolution and Social Change
> Research Assistant,
> Mediterranean Landscape Dynamics Project
> ullah at archaeologist.com
> http://www.public.asu.edu/~iullah <http://www.public.asu.edu/%7Eiullah>
Isaac I Ullah, M.A.
Research Assistant,
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100429/8309fdb7/attachment.html
