[GRASS-dev] Re: [GRASS-SVN] r42980 - grass/trunk/vector/v.db.connect
Markus Metz markus.metz.giswork at googlemail.com
Tue Aug 3 09:32:50 EDT 2010
Markus Metz wrote:
> That was too fast. There is a problem with the new format. It works
> just fine for standard output for one layer, but it has broken some
> modules and wxGUI which rely on one line per layer in the form
> <layer/name>;<table>;<key>;<database>;<driver>
> etc.
reverted, sorry for the noise.
Markus M
> Markus Metz wrote:
>> Martin Landa wrote:
>>> Hi,
>>> 2010/8/3  <svn_grass at osgeo.org>:
>>>>                        else {
>>>> -                           fprintf(stdout,
>>>> -                                   _("layer <%d> table <%s> in database <%s> through driver "
>>>> -                                    "<%s> with key <%s>\n"), fi->number,
>>>> -                                   fi->table, fi->database, fi->driver, fi->key);
>>>> +                           G_message(_("layer <%d>"), fi->number);
>>>> +                       G_message(_("table <%s>"), fi->table);
>>>> +                       G_message(_("in database <%s>"), fi->database);;
>>>> +                       G_message(_("through driver <%s>"), fi->driver);
>>>> +                       G_message(_("with key <%s>"), fi->key);
>>> here I would suggest to use fprintf() instead of G_message(). It's
>>> module's output, not messages. E.g. `v.db.connect vzorky -p --q`
>>> prints nothing.
>> Ah ok, I'll fix it.
>> Markus M
