[GRASS-dev] Re: [GRASS GIS] #1125: wingrass7 - ctypes - compiling error
GRASS GIS trac at osgeo.org
Wed Aug 4 18:40:38 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, ctypes  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by hellik):
 Replying to [comment:5 hellik]:
 > some time ago I had problems with compiling wingrass7 in WinVista32 and
 large file support, because large file support is set automatically by the
 configure step via
 > ./mswindows/osgeo4w/package.sh.
 > so I unset large file support manually in platform.make.
 > #Large File Support (LFS)
 > USE_LARGEFILES      =
 > so maybe this makes the difference in the two error messages?
 if I don't unset manually large file support in platform make, I get
 similar error message like Martin.
 syringia at NADA /c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes
 $ make
 make /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python/grass/lib
 make[1]: Entering directory
 `/c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes'
 make[1]: `/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python/grass/lib' is up to date.
 make[1]: Leaving directory
 make date.py grass.py raster.py gmath.py proj.py imagery.py vector.py
 display.py stats.py dbmi.py g3d.py arraystats.py cluster.py trans.py
 vedit.py ogsf.py nviz.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python/grass/lib/date.py
 mingw32/etc/python/grass/lib/grass.py
 mingw32/etc/python/grass/lib/raster.py
 mingw32/etc/python/grass/lib/gmath.py
 mingw32/etc/python/grass/lib/proj.py
 mingw32/etc/python/grass/lib/imagery.py
 mingw32/etc/python/grass/lib/vector.py
 mingw32/etc/python/grass/lib/display.py
 mingw32/etc/python/grass/lib/stats.py
 mingw32/etc/python/grass/lib/dbmi.py
 mingw32/etc/python/grass/lib/g3d.py
 mingw32/etc/python/grass/lib/arraystats.py
 mingw32/etc/python/grass/lib/cluster.py
 mingw32/etc/python/grass/lib/trans.py
 mingw32/etc/python/grass/lib/vedit.py
 mingw32/etc/python/grass/lib/ogsf.py
 mingw32/etc/python/grass/lib/nviz.py
 mingw32/etc/python/grass/lib/__init__.py
 mingw32/etc/python/grass/lib/ctypes_preamble.py
 mingw32/etc/python/grass/lib/ctypes_loader.py
 mingw32/etc/python/grass/lib/date.pyc
 mingw32/etc/python/grass/lib/grass.pyc
 mingw32/etc/python/grass/lib/raster.pyc
 mingw32/etc/python/grass/lib/gmath.pyc
 mingw32/etc/python/grass/lib/proj.pyc
 mingw32/etc/python/grass/lib/imagery.pyc
 mingw32/etc/python/grass/lib/vector.pyc
 mingw32/etc/python/grass/lib/display.pyc
 mingw32/etc/python/grass/lib/stats.pyc
 mingw32/etc/python/grass/lib/dbmi.pyc
 mingw32/etc/python/grass/lib/g3d.pyc
 mingw32/etc/python/grass/lib/arraystats.pyc
 mingw32/etc/python/grass/lib/cluster.pyc
 mingw32/etc/python/grass/lib/trans.pyc
 mingw32/etc/python/grass/lib/vedit.pyc
 mingw32/etc/python/grass/lib/ogsf.pyc
 mingw32/etc/python/grass/lib/nviz.pyc
 mingw32/etc/python/grass/lib/__init__.pyc
 mingw32/etc/python/grass/lib/ctypes_preamble.pyc
 mingw32/etc/python/grass/lib/ctypes_loader.pyc
 GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/demolocation/.grassrc70
 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32
 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH"
 PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/python;$PYTHONPATH"
 mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/windows/system32:/c/windows:/c/windows/System32/Wbem:/c/Program
 Files/ATI Technologies/ATI.ACE/Core-Static:/c/Program
 Files/ActivIdentity/ActivClient/:/c/Program Files/Hewlett-
 Packard/IAM/bin:/c/Program Files/Common Files/Roxio
 Shared/DLLShared/:/c/Program Files/Common Files/Roxio
 Shared/10.0/DLLShared/:/c/windows/System32/WindowsPowerShell/v1.0/:/c/Program
 Files/TortoiseSVN/bin:/c/Program Files/QuickTime/QTSystem/:/bin" LC_ALL=C
 ./ctypesgen.py --cpp "gcc -E -D_FILE_OFFSET_BITS=64
 -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include
 -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include"
 -lgrass_datetime.7.0.svn  -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686
 -pc-mingw32/include/grass/datetime.h
 mingw32/include/grass/P_datetime.h -o date.py
 Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpjarvxp.h
 Status: gcc -E -D_FILE_OFFSET_BITS=64
 -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__
 -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t"
 "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1"
 Error: gcc -E -D_FILE_OFFSET_BITS=64
 -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: In file
 included from c:\users\syringia\appdata\local\temp\tmpjarvxp.h:1:
 c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-
 mingw32\include\grass\datetime.h:28:30: grass/P_datetime.h: No such file
 or directory
   File "./ctypesgen.py", line 134, in <module>
     descriptions=ctypesgencore.parser.parse(options.headers,options)
   File
 "c:\osgeo4w\usr\src\grass_trunk\lib\python\ctypes\ctypesgencore\parser\__init__.py",
 line 21, in parse
     parser.parse()
   File
 "c:\osgeo4w\usr\src\grass_trunk\lib\python\ctypes\ctypesgencore\parser\datacollectingparser.py",
 line 69, in parse
     ctypesparser.CtypesParser.parse(self,fname,None)
   File
 "c:\osgeo4w\usr\src\grass_trunk\lib\python\ctypes\ctypesgencore\parser\cparser.py",
 line 113, in parse
     self.preprocessor_parser.parse(filename)
   File
 "c:\osgeo4w\usr\src\grass_trunk\lib\python\ctypes\ctypesgencore\parser\preprocessor.py",
 line 196, in parse
     token = self.lexer.token()
   File
 line 51, in token
     result = lex.Lexer.token(self)
   File
 "c:\osgeo4w\usr\src\grass_trunk\lib\python\ctypes\ctypesgencore\parser\lex.py",
 line 343, in token
     raise LexError, ("Scanning error. Illegal character '%s'" %
 (lexdata[lexpos]), lexdata[lexpos:])
 ctypesgencore.parser.lex.LexError: Scanning error. Illegal character '#'
 make[1]: *** [date.py] Error 1
 make: *** [default] Error 2
 but the problem seems to be the same:
 => [...]grass\datetime.h:28:30: grass/P_datetime.h: No such file or
 directory
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1125#comment:7>
