[GRASS-dev] 6.4.0 blocker bugs
Mon Aug 9 20:34:04 EDT 2010
Markus Neteler wrote:
> > two changes I will try to make tonight: backport Paul's
> > g.proj linebreak fix to 6.4 and edit the menu label for
> > v.in.mapgen (it's Matlab compatible ascii, not Matlab
> > format per se). I do not plan on backporting r.in.wms
> > and r.tileset patches as there have been reports of
> > m.proj/cs2cs problems from them.
> > and one last read through of forgotten bug reports.. :)
> great, we are finally close :)
I'd like to just make one final request to remove the swig directory
before release. Otherwise, people will try and use it.
