[GRASS-dev] About v.distance, v.what.vect (wrt "count points within...").
Moritz Lennert mlennert at club.worldonline.be
Tue Aug 10 10:48:48 EDT 2010
On 10/08/10 15:17, Moritz Lennert wrote:
> On 10/08/10 13:49, Nikos Alexandris wrote:
>> Markus M:
>>> If a point is inside an area (the polygon composed of the area's
>>> boundaries), the distance is 0 (zero):
>> This sentence makes me think that it is a priori known (based on
>> something
>> else - related to topology?) when a point is inside an area. Why all
>> the need
>> to measure distances then in order to count how many points are inside?
> As you can see in the code referenced by Markus, there is a
> Vect_point_in_area(), so yes, it is possible to more directly check if
> points are in areas. It all depends on which modules were written using
> this function. At this stage all point-in-polygon attempts in GRASS are
> scripts using workarounds...
As a follow-up:
The counting points in polygons algorithm I prefer at this stage is
(using municipal boundaries and hospitals in the NC data set with an
SQLite backend - DBF won't work):
g.copy hospitals,myhospitals
v.db.addcol myhospitals col="cat_municip int"
v.distance from=myhospitals at sqlite to=boundary_municp at PERMANENT
upload=cat column=cat_municip dmax=0.0
db.select sql="select cat_municip, count(*) from myhospitals group by
cat_municip"
If your hospital attribute table contains number of beds (nbeds), the
you could sum the number of beds as such:
db.select sql="select cat_municip, sum(nbeds) from myhospitals group by
cat_municip"
etc...
Using 6.5 to test a similar case to yours (I assume):
g.region vect=boundary_municp
v.random out=mypoints n=600000
v.db.addtable mypoints col="cat int, cat_municip int" (that's veeeeery
slow, probably because of 600000 update statements to the database in
the v.to.db call...)
time v.distance from=mypoints at sqlite to=boundary_municp at PERMANENT
real	2m2.119s <= not so bad
db.select sql="select cat_municip, count(*) from mypoints group by
cat_municip"
So, using the combination of v.distance and db.select I cannot reproduce
your problem with 600,000 points, but maybe the number and nature of
polygons can also play a role...
Moritz
