[GRASS-dev] Re: 3D vector support in v.overlay
Sylvain33 kikiesttoujoursla at gmail.com
Wed Aug 11 04:39:26 EDT 2010
In fact, it didn't work as I expect:
See the screenshot, you will see the difference between v.overlay2D and
v.overlay3D (operator and as intersect).
v.overlay3D produce 2 layers and the result is very bad
v.overlay2D => http://yfrog.com/afvoverlay2dp
v.overlay3D => http://yfrog.com/n3voverlay3dp
How could I improve this to work that I expect (v.overlay2D) to produce a 3D
vector?
How could I work around the problem ?
Thanks in advance
View this message in context: http://osgeo-org.1803224.n2.nabble.com/3D-vector-support-in-v-overlay-tp4610942p5411421.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
