[GRASS-dev] About v.distance, v.what.vect (wrt "count points within...").
Moritz Lennert mlennert at club.worldonline.be
Wed Aug 11 05:11:54 EDT 2010
On 10/08/10 17:53, Markus Metz wrote:
> OK, here comes (soon) a speed-up for v.distance
> Results for the 10000 points are identical (distance to nearest area
> and category of nearest area).
> The code is now a bit more complicated, but reducing processing time
> for distance calculations from over 6m down to 2s might justify some
> code complexity.
Wow !
Could you explain (briefly) what you did ?
Moritz
