[GRASS-dev] About v.distance, v.what.vect (wrt "count points within...").
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Aug 13 05:25:43 EDT 2010
Markus M:
> I've put a new module in grass-addons, called v.vect.stats.
I just want to confirm that this is _fast_. Tested under grass6_devel. The
module fails to compile though under grass64, grass_trunk (see attached
files).
Nikos
gcc -I/geo/osgeo/src/grass64_release/dist.x86_64-unknown-linux-gnu/include  -g    -I/usr/local/include    -DPACKAGE=\""grassmods"\"  -I/geo/osgeo/src/grass64_release/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
gcc  -g   -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include  -D_FILE_OFFSET_BITS=64 -I/usr/local/include -I/usr/local/include -DPACKAGE=\""grassmods"\"   -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
