[GRASS-dev] Re: [GRASS GIS] #1131: Global LFS for wingrass
GRASS GIS trac at osgeo.org
Sun Aug 15 11:07:37 EDT 2010
 Reporter:  mmetz         |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  critical      |   Milestone:  7.0.0
Component:  libgis        |     Version:  svn-trunk
 Keywords:  LFS,wingrass  |    Platform:  MSWindows 7
      Cpu:  All           |
Comment(by hellik):
 Replying to [comment:9 mmetz]:
 > Needs more testing, I can compile grass7, errors are ctypes, but I can't
 get it running for various reasons, a bit arbitrary. Grass7 can't start
 the shell using /C/OSGeo4w/apps/msys/bin/sh.exe although that file
 exists??? Sometimes grass7 can't find the .gislock file in the mapset I
 want to use. Mysterious. Configuration and compilation with cairo worked
 fine BTW.
 > Markus M
 I've never managed running grass7 in C/OSGeo4w/apps/grass/bin or in
 c/osgeo4w/usr/src/grass_trunk/bin.i686-pc-mingw32  after changing the
 startup script from a shell to a python script.
 so I build my own WinGrass7-installer and install wingrass7 in c/Program
 files/Grass-7.0.svn and from there WinGrass7 is starting.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1131#comment:10>
