[GRASS-dev] grass7 compilation error
Markus Metz markus.metz.giswork at googlemail.com
Tue Aug 17 02:52:32 EDT 2010
Glynn Clements wrote:
> Markus Metz wrote:
>> fixed in r43137
> Regarding the comment:
>> LFS for wingrass: another old name. use typedef instead of define?
> In general, you should use typedef's for types. #define should be a
> last resort, as it affects all use of the name regardless of context.
OK
> Also, what is the reason for defining _NO_OLDNAMES? Is there no
> alternative?
Looking for one, but I do not get the initial approach with
#define lseek lseek64
to work, see ticket #1131.
Anyway, I will be out of office for some days, let's leave it
deactivated for the time being.
Markus M
