[GRASS-dev] 6.4.0 blocker bugs
William Kyngesburye woklist at kyngchaos.com
Wed Aug 18 15:23:32 EDT 2010
I'll follow whatever is decided.  I probably don't need to set a default GRASS_GUI in the Mac startup (just let init.sh handle the default), except that I do need to make *some* assumption about a setting to work around an application focus issue in OSX Tiger.
I'll see if I can figure out a less intrusive test for the GUI setting.
On Aug 18, 2010, at 1:58 PM, Helena Mitasova wrote:
> as Hamish has noted the choice of the default GUI is decided by whoever does the binary package (?).
> So my plea was pretty much for William to make wxGUI default in his Mac binary.
> People who run linux or compile GRASS from source are generally used to customizing so that is
> not so much an issue. It is really for newcomers who download GRASS binary and start GRASS
> and then the first thing they have to deal with is to change GUI.
> The biggest issue that the newcomers had with the TclTk GUI (and that was solved in wxGUI) was
> - "why the map is not displayed when I load it into gis manager?"
> All of this made starting with GRASS on Mac unexpectedly more difficult than on MSWindows.
> At this point our semester has already started so I will have to deal with it , and if I understand
> the process correctly, 6.4 can be released with TclTk as default but with MSW and Mac binaries packaged
> with wxGUI as default. Of course, I would much prefer if the release was with wxGUI as default.
> I don't have enough expertise on ctypes but we have troubles with it on our enterprise linux
> when compiling, but that is just a local problem,
> Helena
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
