[GRASS-dev] G_open_cell_old: unable to open raster map
James McCreight mccreigh at gmail.com
Wed Aug 18 17:28:11 EDT 2010
Greetings-
I've been forced in to development by this bug (ie i have a only a vague
idea of what I'm doing). Help greatly appreciated (need to work on thesis
not bugs).
Summary:
I've generated a location and a mapset, in this mapset I have files named
input_file.0001, ... , input_file.nnnn, ... , input_file.3313
I'm running  r.hydro.CASC2 (used to be in GRASS), which i've built from gipe
add-on package.
When it gets to approximately nnnn=1016, i get (i'll use the real rast and
mapset names, in case they are relevant):
WARNING: Unable to open raster map
<SBB_runoff_lumped_05.1016 at lumped_05_9930>
The offended block of code in r.hydro.CASC2D is
 if((radar_fd[nfile]=G_open_cell_old(radar_file[nfile],mapset))<0)
              sprintf(buf,"cannot open [%s]\n", radar_file[nfile]);
              G_fatal_error(buf);
      exit(1);
But the file is right in place, looking all fine and dandy. I've also tried
copying input_file.1015 to input_file.1016 using both the gui and on command
line. I still get no error for 1015, only for 1016. Also, if i comment
I'm at a complete loss. Is there a bug in G_open_cell_old? Something which
suggests otherwise: if i comment out the above code, CASC2D apparently runs
until that same map is to be read by G_get_map_row(), at which point I dont
even get a warning, but a seg fault. )
Thanks in advance.
James
James McCreight                                  mccreigh @at@ colorado.edu
NASA Earth Science Fellow
PhD Candidate, Water Resources and Environmental Fluid Mechanics
University of Colorado, Boulder
cell: (831) 261-5149
VoIP (to cell): (720) 897-7546
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100818/4d01cf17/attachment.html
