[GRASS-dev] grass + vtk , which vtk version
Massimo Di Stefano massimodisasha at gmail.com
Thu Aug 19 04:06:40 EDT 2010
Hi All,
i'm intersted to use the vtk-grass-bridge [1] ,
i've few questins about it .
Can i use the latest stable release : VTK - 5.6
instead of the suggested version ( VTK - 5.4) ?
... have you any clue if this beatifull work will be "ported"  to run under grass6.x ?
thanks!
Massimo.
[1] http://code.google.com/p/vtk-grass-bridge/
