[GRASS-dev] [GRASS GIS] #1132: wxNviz and wxVdigit missing from 6.4svn
GRASS GIS trac at osgeo.org
Thu Aug 19 08:00:26 EDT 2010
 Reporter:  hamish   |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  6.4.0
Component:  wxGUI    |     Version:  svn-releasebranch64
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
 wxNviz and wxVdigit are missing from 6.4svn in a build using the latest
 svn. platform is debian/lenny amd64.
 CFLAGS="-ggdb -march=amdfam10 -Wall -Werror-implicit-function-declaration"
   ./configure \
     --with-tcltk-includes=/usr/include/tcl8.5 --with-cairo \
     --with-motif --with-python=/usr/bin/python2.5-config \
     --with-readline --with-cxx --with-odbc --with-sqlite \
     --with-freetype --with-freetype-includes=/usr/include/freetype2 \
     --without-postgres --with-proj-share=/usr/share/proj \
     --enable-64bit --with-pthread \
     --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
     --with-geos \
     2>&1 | tee config_log.txt
   Python support:             yes
   wxWidgets support:          yes
 $ make -j 8
 Errors in:
 No errors detected.
 grass/svn/releasebranch_6_4$ ls dist.x86_64-unknown-linux-
 gnu/etc/wxpython/
 README   gis_set.py    icons/   scripts/  xml/
 compat/  gui_modules/  images/  wxgui.py
 grass/svn/releasebranch_6_4$ ls gui/wxpython/nviz/OBJ.x86_64-unknown-
 linux-gnu/
 _grass6_wxnviz.so*  grass6_wxnviz_wrap.o  load.o     volume.o
 change_view.o       init.o                surface.o
 draw.o              lights.o              vector.o
 grass/svn/releasebranch_6_4$ ls gui/wxpython/vdigit/OBJ.x86_64-unknown-
 linux-gnu/
 _grass6_wxvdigit.so*  driver_draw.o           message.o   vertex.o
 cats.o                driver_select.o         pseudodc.o
 digit.o               grass6_wxvdigit_wrap.o  select.o
 driver.o              line.o                  undo.o
 seems it isn't being installed.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1132>
