[GRASS-dev] Re: [GRASS GIS] #1129: Menu strings may be changed and not reflecting PO-files.
GRASS GIS trac at osgeo.org
Fri Aug 20 09:50:23 EDT 2010
  Reporter:  naokiueda     |       Owner:  grass-dev@…
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Translations  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  i18n
  Platform:  Unspecified   |         Cpu:  Unspecified
Changes (by neteler):
  * status:  closed => reopened
  * resolution:  invalid =>
Comment:
 With apologize I open it again - indeed the menustrings.py messages where
 deleted in an incorrect template update (performed in an uncompiled GRASS
 source code tree). All grasswxpy_*.po files have been restored in SVN
 (except for DE, IT, PL which will follow shortly).
 The closing of the ticket as invalid was due to a misunderstanding of the
 problem.
 And it is unrelated to the length of the RC cycle but a technical problem.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/1129#comment:5>
