[GRASS-dev] double check vector display on MSWindows
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Aug 24 11:30:25 EDT 2010
I got it confirmed fixed from both,
one of them is actually running the class assignment with the  winGRASS exe that you have just posted
so it is getting tested right away
  Helena
On Aug 24, 2010, at 11:19 AM, Martin Landa wrote:
> Hi,
> 2010/8/24 Helena Mitasova <hmitaso at unity.ncsu.edu>:
>> I believe this has been fixed but I just got a complaint about GRASS crashing when vectors
>> are displayed (this is with the currently available RC6 on VISSTA and this guy is known to have troubles
>> with everything, so it may be just his particular set up). It may be good to check before the release
>> because I had another experienced GRASS user reporting this on windows - he has several versions
>> of python on his machine so I am wondering whether that may be related.
> yes, it should be fixed [1].
> Martin
> [1] http://trac.osgeo.org/grass/ticket/1020
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
