[GRASS-dev] [GRASS GIS] #1137: wxGUI doesn't work in Windows
    trac at osgeo.org
    Wed Aug 25 07:54:19 EDT 2010
 Reporter:  glynn    |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  6.4.0
Component:  wxGUI    |     Version:  unspecified
 Keywords:           |    Platform:  MSWindows XP
      Cpu:  All      |
 In menuform.py, getInterfaceDescription() attempts to insert the full path
 to grass-interface.dtd in the --interface-description output, using:
     p = re.compile('(grass-interface.dtd)')
     p.search(cmdout)
     cmdout = p.sub(globalvar.ETCDIR + r'/grass-interface.dtd', cmdout)
 But the first argument to the !RegexObject.sub() method is a replacement
 '''pattern''', not a literal string, meaning that certain backslash
 sequences have special meaning.
 This is problematic if globalvar.ETCDIR contains a recognised backslash
 sequence, which is quite likely on Windows. In particular, \g is used to
 insert the contents of a named or numbered group, and ETCDIR will almost
 certainly contain this sequence as part of "\grass-". This results in the
 error:
   File "C:\msys\1.0\home\glynn\src\grass-7.0\dist.i686-pc-
 mingw32\etc\gui\wxpython\gui_modules\menuform.py", line 1997, in
   File "C:\Program Files\Python26\lib\re.py", line 273, in _subx
     template = _compile_repl(template, pattern)
   File "C:\Program Files\Python26\lib\re.py", line 260, in _compile_repl
     raise error, v # invalid expression
 sre_constants.error: bad group name
 Also, even without the error, the "\1" in "\1.0" would end up being
 replaced by the first parenthesised group (grass-interface.dtd).
 As the pattern is a literal string, I don't see any reason to use regular
 expression. It may as well just use e.g.:
 cmdout.replace('grass-interface.dtd', os.path.join(globalvar.ETCDIR,
 'grass-interface.dtd'))
 which also fixes the use of the wrong directory separator.
 Also, if the DTD is supposed to be specified by a full path, the
 implementation of --interface-description should be fixed, rather than
 patching the output afterwards.
 Priority set to "blocker" as this can make the wxGUI effectively non-
 functional. Executing any command will trigger the error if $GISBASE
 contains the wrong characters (this may be specific to Python 2.6; I can't
 see any other reason why it wouldn't have been noticed earlier).
 Platform set to "MSWindows" (applies to all versions) as backslashes in
 pathnames are uncommon on other platforms (although technically
 permitted).
 Tested with the latest 7.0, but the code is identical in 6.x.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1137>
