[GRASS-dev] [GRASS GIS] #1139: v.report has a problem (only via OSGEO4W package)
GRASS GIS trac at osgeo.org
Wed Aug 25 22:50:22 EDT 2010
 Reporter:  naokiueda    |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  Vector       |     Version:  6.4.0 RCs
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 with version GRASS 6.4.0svn
 v.report does not work.
 when run, it cause following error.
 "Input file specified two times.
 There is a table connected to input vector map '*****', but there are no
 categories present in the key column '***'. Consider using v.to.db ro
 correct this."
 Malfunctioning on GRASS 6.4.0.SNV included in OSGEO4W version on windows7.
 g.version -r returned following.
 RASS 6.4.0svn (2010)
 Revision: 37101
 Date: 2009-05-10 13:35:38 +0200 (Sun, 10 May 2009)
 Note that it working normally on single version of GRASS with same
 version. (Download from Web and install as a independent application
 istead of installed as a OSGEO4W package)
 Working version also returned same version, but different time stamp.
 Revision: 37101
 Date: 2009-05-10 04:3538 -0700 (Sun, 10 May 2009)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1139>
